Issues with interior lights
Old Sep 11, 2011 | 11:12 PM
ckim715's Avatar
Default Issues with interior lights
Recently, my interior lights, door chime, and key chime have all stopped working. I cannot turn the lights on by switch or button, nor will they come on when my door is open. Furthermore, neither my open door chime or my key-in-ignition chime work. My headlight on chime does. Any ideas? Thanks
Old Sep 12, 2011 | 05:20 AM
MasterForce's Avatar
you check fuses?
Old Sep 12, 2011 | 08:35 AM
ckim715's Avatar
checked the 7.5 amp interior light fuse, seemed in tact.
Old Sep 12, 2011 | 11:58 AM
T-Smac's Avatar
will they come on when you hit the unlock on your Keyless entry?
It sounds like its the KEM (Keyless Entry Module) as it controls both the chime and the lights. That's the best I can think of without looking at a diagram (which I can do tomorrow if this isn't resolved)
Old Sep 12, 2011 | 08:49 PM
ckim715's Avatar
Thanks for the suggestion. KEM may have a part in it; however, I don't understand why the dome lights will not function at all, regardless of switch position, or button. They just don't work period. I'll look into the KEM tomorrow morning.
Old Sep 13, 2011 | 04:42 AM
T-Smac's Avatar
Does either door opening cause the door ajar light to come on? What about the light in the trunk?
Old Sep 13, 2011 | 04:59 AM
T-Smac's Avatar
Well if the trunk light comes on but not the indicators (door ajar), then both bulbs are blown most likely. If the trunk light is out then fuse 24, 7.5A under dash is blown
Old Sep 13, 2011 | 08:25 PM
ckim715's Avatar
Bought new bulbs, and nothing. Trunk light is on, so the 7.5 interior fuse is good. I'm stumped. It's got to be a short somewhere, I just can't figure out where.
Old Sep 13, 2011 | 09:11 PM
T-Smac's Avatar
So did you have the door ajar indicators? Check the connection going to the dome light. I left the wiring diagram at work (go figure) but I don't remember where else the problem could have been. What you have is an Open circuit, a short would cause either blown fuses or other electrical devices to be turning on/off when they shouldn't be.
Old Sep 14, 2011 | 06:56 AM
ckim715's Avatar
Door ajar indicator works
