ITB Troubles
Old Aug 31, 2007 | 08:37 AM
Asura's Avatar
Originally Posted by alejo,Aug 31 2007, 08:27 AM
/\ true but I really doubt it.
Lots of rodents in the bay
Old Aug 31, 2007 | 08:40 AM
alejo's Avatar
lol - I'm sure he loves that photo
Old Aug 31, 2007 | 09:11 AM
RWD_RCKT's Avatar
I've got a compression gauge. Ashish has the laptop. We can fuxors with it this weekend... Sunday/Monday though is the soonest for me.
No one except a dyno shop or a smog station will have a sniffer. So unless you have another sensor to try out, you need to go to a shop.
7 is shite at idle... IT SHOULD BE DOUBLE THAT. Do you have any readings under part throttle? I would definitely not drive though if you don't as you don't want fuel to wash the cylinders of oil.
Did you pull the plugs and check em??? Any plug fouling???
Did you try and reload the map???
Old Aug 31, 2007 | 09:12 AM
RWD_RCKT's Avatar
That photo is sexy.
Old Aug 31, 2007 | 09:20 AM
alejo's Avatar
gimme a call bro
Old Aug 31, 2007 | 09:27 AM
Asura's Avatar
If the afr is 7:1 the car will barely move. Chances are the sensor is bad and the part throttle corrections are being affected. Sunday it is. We'll compare calendars tonight
Old Aug 31, 2007 | 09:34 AM
alejo's Avatar
awesome
Old Aug 31, 2007 | 10:37 AM
S2000_Europe's Avatar
alejo
with 7 a/f the wont start.
When I was running 575cc injectors, + 50% bigger than stock, with sotck ECU and no engine management, the car was running 10 A/F at ilde.
It seems that you have a bad O2 Sensor
Old Aug 31, 2007 | 10:42 AM
alejo's Avatar
Originally Posted by S2000_Europe,Aug 31 2007, 11:37 AM
alejo
good to know now i have to figure out what is causing the power loss and rough idle.
Old Aug 31, 2007 | 11:37 AM
RWD_RCKT's Avatar
Shooting in the dark...
Are you using the 02 sensor from the original 1052 that you bought? Isn't there a calibration resistor in the wideband that is specific for each 1052?
If you are using the old 02 sensor, and the calibration is okay, do you know if the original guy used leaded gas with it?
