Jacking up our s2000 from the rear
I agree with everyone and I also go a bit overboard with extra supports in addition to jackstands where possible. Wit the exhaust system the hangers can get a bit sticky at times , so if you have to do some tugging do it from outside of the vehicle, rather than underneath, just in case it upsets the balance of the vehicle. Some good lube on the hangers helps.
4 stands or a hoist. There is no other alternative unless you want to run the risk of being crushed by your car because you were too cheap to get yourself 2 more stands.
Your life > ~$50
You can then use the jack to help support the exhaust as you remove it.
Your life > ~$50
Thanks guys, s2ki is probably the safest car community . Other forums are just saying that nothing will happen as long as the front wheels are chocked.
Hmm, nobody is mentioning anything about ramps. Since I'm not talking about taking off my wheels, ramps seems like a really good idea. I'm thinking about the RhinoGear 11909 as well as a second pair of stands.
Received 1,563 Likes
Nothing like solid wood. I have a couple of 2X6s with the leading edge cut at 45 degrees to elevate the front tires enough to get my jack under the front lip (my car is stock).
I could make one higher but I personally don't see a need for it. Its so easy to jack it up and add stands. I have a Fumoto valve for oil changes so I don't need to do anything under the car for an oil change. Oil change is from the open hood. My annual trans and diff fluid change are that: once a year. Jack it up!
Lateral loads on the jackstands can strain them and cause them to fail or slip. You can eliminate that by jacking up the front, putting it on stands, then jacking the rear, putting it on stands, then jacking up the front again a tiny bit off the stands and then lowering it. Probably overkill but if my S2000 is going to kill me it's not going to be from falling on me I hate getting under my car on stands and avoid it as much as I can - fortunately there's a garage in my area with lift bays for rent at $15 an hour, and with my Fumoto valve I can do an oil change without getting under the car.
Rubber jack and stand inserts are cool too, especially for the pinch weld points. Never had them before but I want some.
http://www.prothanesuspensionparts.c...sp?prod=191405
http://www.harborfreight.com/2-piece...and-95952.html
I hate my Rhino ramps. I used them once and said never again. Get a low profile floor jack (Harbor freight has some good ones that are popular) and 4 quality jack stands. Personally, I start raising the car from the front subframe, but the foam on the jack handle touches the bumper so some may not like that (even though I don't car, it doesn't damage anything since it's protected by foam padding) then get the front up on stands, then move to the back and lift from the differential bolt (remember to use a shop rag or you can dent/ding the differential case) then put the other two stands under.
Takes me maybe 5 minutes, 10 minutes tops.
http://revlimiter.net/blog/2010/07/m...tand-review-1/
I have two types, the Torin ones ( I like them, use them a lot but got mixed reviews here.) Very solid when I shake the car.
Also have steel/cast 4 point set, much larger and heavier. Bullet proof. Costco 20 years ago.
