J's racing header
Old Mar 4, 2005 | 12:37 PM
B SweepeR B6's Avatar
Default J's racing header
Hey guys, i am going to go with the J's racing header 70mm i believe it is but ima get the the dual amuse exhaust and I was wondering if i get the dual amuse will it fit the j's exhaust mani? n will the header fit before i purchase an exhaust? or it wont fit on the car w/out an exhaust? i am confused on that part.
Old Mar 4, 2005 | 12:42 PM
StinkyTofu's Avatar
Doesn't really matter what size the header is because the cat-back will be connecting to the cat and not the header. I'm not sure if you need to get a new cat because of the different collector size of the J's header, but having a stock exhaust or dual amuse will not make any difference in terms of fitment.
Old Mar 4, 2005 | 12:47 PM
ohh ok. thaanks a lot! do you think that setup will help out performance pretty well?
Old Mar 4, 2005 | 02:48 PM
_SpeedStar_'s Avatar
Banned
I think the setup will allow for a much better power gain
Old Mar 5, 2005 | 12:43 AM
JL9000's Avatar
The collector size really doesn't have much to do with fitment, as the flange has the same specs as any other header.
Old Mar 5, 2005 | 03:32 AM
S2KPUDDYDAD's Avatar
You may be better off to get a less expensive header, any gain you would have got with the big tube header from J's will be lost. The use of a cat and not a test pipe, smaller pipe size of the Amuse exhaust (2 1/2"), not to mention the added weight of duals. If you like the J's header go with a 70mm single exit exhaust
Old Mar 5, 2005 | 07:10 AM
POACHER's Avatar
bang for the buck, use a 70mm test pipe & single exhaust!!!!!!!!!!!!! just my 2 cents, anybody else, chime in..............
Old Mar 5, 2005 | 08:28 AM
As I wrote in my post, just with some explanation
If you go with a 3" header go all the way with 3" exhaust
Old Mar 5, 2005 | 12:27 PM
yellowknockers's Avatar
J's Racing header is not compatible with the stock cat, it says that in their advertising. If you have the funds for this head, don't sell yourself short, also pick up their 3"/70mm exhaust system which has the straight pipe built in.
There's very few if any of these state side, so you'd be in rare company if you get them. Careful though, they're loud and may be unreasonable for street use, but if you have bad hearing like me, who gives an f[][][].
Old Mar 5, 2005 | 12:51 PM
tabach0y273's Avatar
Is this really true?? I was planning on getting this header and then sticking the cat in whenever it came time for emissions (running T1R 63mm with test pipe). I wouldnt want to change out BOTH the header and cat. If this really is true, I'd have to get something more streetable.
