Jerkiness on acceleration
This is something that I've noticed with my car for the last few weeks. Obviously someone that is not driving a car with a manual transmission properly will experience some jerkiness but I've had this car for 3 1/2 years and haven't driven anything but standards since 1999 so I do not believe my driving skill is the culprit here. At first I thought I was just having 1-2 of those random bad days with shifting. However the problem has persisted and no matter how I drive the car unless I gradually increase the throttle there is some jerkiness that resonates through the drivetrain. It even makes the engine rpm dip for just a second as a side effect (easily felt and heard through the exhaust note).
Anyone have any suggestions? Perhaps a broken transmission or engine mount? I had a buddy look at my engine while revving it and it looked secure. Of course that was while in neutral and under no load. I just took the car on a 1200 mile trip and it performed flawlessly except for this issue.
Car background:
2007 AP2
55,000 miles
original clutch
stock other than Invidia exhaust
While I do most routine maintenance items on this car it does have a 100,000 mile warranty so anything moderate to major I take it to the dealership for. Any help/advice would be greatly appreciated.
Car background:
2007 AP2
55,000 miles
original clutch
I've experienced the jerkyness too and it usually happens coming from a stop shifting into second for me... I have seen threads on this before and I believe they sad the culprit was the drive by wire system in the 06+ S.
Don't quote me but I want to say gernby or someone who is familiar with tuning 06+ with flashpro mentioned this and that a tune could almost remove all of this jerky bog/hesitation. I think I had something to do with the computer changing timing drastically to avoid knock??
I'm on my phone but do a search and you'll find the thread. I've learned to just deal with it for now :-/.
Happen in 1st or 2nd on partial throttle?
The partial throttle mapping for the DBW is not very smooth.
I had help remapping mine with the Flashpro and now the partial throttle is sublime-really smooth and nice.
This might be a quick fix.
https://www.s2ki.com/s2000/topic/492...ean-iac-valve/
Mine does this too every great now and then so I'll probably pull my IACV when i replace the cat in a couple weeks to see how dirty it is and clean it.
Try the above, and also try cleaning your intake and MAP sensor a bit. I have/had similar problems recently. Cleaning my MAP sensor area has helped a lot. I had the same problems you were having and after a few weeks I eventually threw a code for a faulty map sensor. I cleaned it up and it has improved a lot and took care of the CEL. I'm still not running 100% normal yet. I'm going to try the IACV DIY above and see if that fixes me.
