Just bought an S2000 yesterday
Old Jun 24, 2008 | 08:41 AM
ClassicFlava's Avatar
Default Just bought an S2000 yesterday
SO i just bought an S2000 yesterday. Silverstone 2001 59,000 niles. I was wondering if there is anything i should look out for mechanically on the car. I dont know that much about S2000's. Thx for all your help.
EDIT: just noticed today that the engine makes a little bit of a whistleing sound undre light acceleration around 3-4k rpm. Is this normal?
Old Jun 24, 2008 | 08:43 AM
2big4aS2000's Avatar
at 60,000 = complete fluid change - trans, diff, breaks, clutch, and have valves adjusted
Old Jun 24, 2008 | 08:44 AM
go to honda for that?
Old Jun 24, 2008 | 08:45 AM
Danks2k's Avatar
Also check to make sure your spark plugs are torqued properly. Since you have an '01 you may want to upgrade to the updated oil jet bolts but it is not necessary.
Old Jun 24, 2008 | 11:33 PM
so i have been reading about the timing chain tensioner going bad. How loud is the clicking noise? At times i think i hear a faint noise like the one described, but i am not sure. Anyone know about that whistleing sound at 3-4k rpm i described? thx for all your help
Old Jun 25, 2008 | 06:14 AM
mattfeet's Avatar
Whistling sound = intake noise
It's 100% common and nothing to worry about.
-Matt
Old Jun 25, 2008 | 06:23 AM
negcamber's Avatar
You'll know when the TCT goes out. The car will sound like a diesel.
For the basic fluid changes and valve adj, I probably wouldn't take it to a dealer. Check out the regional s2ki forums...post in your region's forum and ask for a shop recommendation in your area. Use Honda MTL for the tranny, OEM pads, and Mobil 1, Redline or LE gear oil for the diff. The shop should have a decent DOT 3 fluid for the brakes & clutch.
Old Jun 25, 2008 | 08:43 AM
awesome info thx
06s2kid
Apr 13, 2016 04:57 PM
CTMechE
Jan 18, 2012 08:26 PM
jamieM
Sep 18, 2007 01:45 PM
rustywave
Mar 19, 2006 10:21 AM
m777erlin
Oct 3, 2002 11:20 AM
