K&N filters contaminating MAP sensor?
Old Sep 27, 2009 | 01:01 PM
kulivontot's Avatar
Default K&N filters contaminating MAP sensor?
I'm sure this has been asked before, but search appears to be broken.
Can oil-covered reusable filters contaminate the MAP sensors on an S2000? I've heard of this happening with the hot-wire MAF sensors on older cars, but is this a valid concern on the S2000?
I like the idea of a reusable filter, especially in the hella dusty state of Arizona, but I'm not too thrilled about mucking up an expensive air sensor.
Old Sep 28, 2009 | 12:52 PM
starchland's Avatar
of course this can happen to anyone one of the sensors on your engine. follow the kn instruction and you will never have a problem. Having said that, many hondas run kn intakes and filters and have gone on to live long prosperous lives.
Old Sep 28, 2009 | 01:46 PM
AusS2000's Avatar
No, this will not happen (if you don't do anything stupid like over oil your filter).
Old Sep 28, 2009 | 02:29 PM
phaphapho's Avatar
Only messes with Maf sensors to my knowledge.
Old Sep 28, 2009 | 05:05 PM
japhethwar's Avatar
k&n filters do cause a lot of problems on mass air cars and they can contaminate iat sensors on dbw vehicles. I mechanic for a living and i've seen numerous issues with the oiled filters. Do yourself a favor and get an aem dryflow or other non oiled filter, they flow better and never need oiling. Also, much easier to clean. Oiled filters are for dirt bikes and 4 wheelers not cars.
Old Sep 28, 2009 | 05:36 PM
Moddiction's Avatar
Former Sponsor
Old Sep 28, 2009 | 05:59 PM
Slows2k's Avatar
Since no S2k uses a hot wire MAF, not an issue.
That said, you don't need to be soaking a KN in oil to make it work.
Old Sep 28, 2009 | 08:57 PM
gospeedgo1's Avatar
AEM does not make a dryflow filter for the stock s2000 intake. emailed them a couple months ago. if you want a dry synthetic filter, aFe makes a Pro Dry S.
http://afepower.com/performance_airfilters.php
Old Sep 29, 2009 | 09:35 AM
redlineracing's Avatar
I use K&N on all my cars..never a problem.
I clean the filters as part of my 4k OCI.After cleaning I re-oil the filter with the KN spray can.I let it sit for about 10min to soak thru,then blot dry with a towel.
If I over spray it,I'll use the leaf blower for about 5 sec to blow out the excess.
If you spray the oil on the filter and rev the engine to suck it thru,you could possibly have a problem with the MAF,but I doubt it.
\rlr
Carolina
Old Oct 4, 2009 | 08:45 PM
kulivontot's Avatar
How exactly does the AFE oil-less reusable filter work exactly? The description on their site states:
"this high flow, oiled OE replacement performance filter will outflow stock paper filter for improved horsepower and torque"
Is it oil-less in that you don't have to add oil to the outside of it, yet there's still layers underneath which are pre-oiled from the factory?
