keep throwing a misfire code for #1
Old Feb 10, 2014 | 09:12 PM
andrew87890's Avatar
Default keep throwing a misfire code for #1
so 2 months ago i did a valve adjustment because i kept getting a misfire codes in all 4. did the adjustment the codes cleared. was driving tonihgt it was very cold and the light came back on but just for #1
fuel sys 1 CL
fuel sys 2 NA
calc load% 30.2
ect 187
SRFT B1 -7.8%
LTFT B1 0.0%
MAP (inhg) 8.9
that was the freeze from from my obd2 scanner
Old Feb 11, 2014 | 06:44 PM
DeeKay's Avatar
you've already checked injector, plug, coil?
Old Feb 11, 2014 | 08:17 PM
2003AP1's Avatar
Easiest way is to swap the coil pack. See if misfire follows.
If not then swap plug. See if misfire follows.
Simplegreenvr6
Dec 4, 2012 10:06 PM
evoluder
Mar 30, 2010 05:40 PM
ZeroF
Mar 29, 2010 02:08 PM
REVZ TO9
Feb 16, 2007 07:18 PM
anthon_E
Jun 23, 2006 07:14 AM
