Kindly identify 4 wires
Old Apr 8, 2026 | 04:01 PM
s2kseven's Avatar
Default Kindly identify 4 wires
I bought an AP1 2001 Engine wiring harness.
I like to identify 4 connections.
1. Black w/ red stripe (one wire) oil sensor?
2. Red w/ black stripe (one wire) look like coolant temp?
3. Inside sensor is white but broken (look like ceramic)
4. Two wires - yellow and the other is black
Near the injector.
Thank you
so much
Old Apr 9, 2026 | 01:46 AM
JBamin's Avatar
1 is ac compressor
2 is a knock sensor
3 is starter
4 is cam sensor
this is just me giving it a wild shot from memory.
Old Apr 9, 2026 | 04:52 AM
s2kseven's Avatar
Originally Posted by JBamin
1 is ac compressor
2 is a knock sensor
3 is starter
4 is cam sensor
RIGHT ON!!!
I appreciate very much.
Old Apr 9, 2026 | 06:14 AM
engifineer's Avatar
ah and a good old broken knock sensor still plugged into the harness even
Old Apr 11, 2026 | 01:37 PM
s2kseven's Avatar
1 is ac compressor
2 is a knock sensor
3 is starter
4 is cam sensor
oh, I forgot one more plug with broken wire.
Green and Red
What plug is this?
Old Apr 12, 2026 | 08:19 PM
JBamin's Avatar
I think I am wrong looking at that first picture again... 3 isnt for the starter. the one between 3 and 2 is. I believe that is coolant temp sensor plug. does it have a white line on the red wire? then its temp.
For the new one you posted I believe that is cam sensor 1 or sensor A and the one that was cut off number 4 is cam sensor 2 or B.
1 or A should be red and green wires no stripe, Goes on intake manifold side of the valve cover.
2 or B should be yellow and black wires no stripe. Goes on the top of the valve cover.
Old Apr 13, 2026 | 04:26 AM
s2kseven's Avatar
[QUOTE=JBamin;25156447]I think I am wrong looking at that first picture again... 3 isnt for the starter. the one between 3 and 2 is. I believe that is coolant temp sensor plug. does it have a white line on the red wire? then its temp.
The #3 has RED with a white stripe and GREEN with a yellow stripe.
I extracted the white broken sensor shown beside the connector plug.
Old Apr 13, 2026 | 07:27 AM
JBamin's Avatar
Yep, then number 3 was coolant temp sensor.
Old Apr 13, 2026 | 09:37 AM
s2kseven's Avatar
Thank you, JBamin - I owe you a lunch.
I am doing a Lotus 7 type car and using F20C engine.
Old Apr 14, 2026 | 01:15 PM
JBamin's Avatar
I saw your thread where you mentioned it. Glad to to help, hope it turns out good.
AP1Jonathan
Jul 31, 2019 05:44 AM
SoCalIsMyLife
Nov 26, 2011 12:40 AM
KC2001AP1
Apr 13, 2010 01:41 PM
PatS4P
Apr 5, 2008 01:53 AM
lotus7racer
Oct 2, 2007 01:51 PM
