Knock sensor differences.
Old Jul 16, 2012 | 04:38 PM
AFs2k's Avatar
Default Knock sensor differences.
What are the differences here? Are the parts different freqs? Are the wiring pins on the backside of it different?
I would assume the blocks knock the same freqs, its the same casting and all. Just want to know because I'm putting an '09 block in my '05. I'm pretty sure I could just use my '05 sensor and be good to go.
2000 - 2005 uses part number (30530-PCX-003)
2006 - 2009 uses part number (30530-PRC-003)
Old Jul 17, 2012 | 03:31 AM
AFs2k's Avatar
Old Jul 17, 2012 | 06:42 AM
S2000Guatemala's Avatar
I live in Guatemala, Central America, the dealer only had CR-V's sensor, and thats what i´m using. Just hope that nothing gets ruined in the long run. Maybe someone can help with your question.
Old Jul 17, 2012 | 09:51 PM
rob-2's Avatar
I believe they are different spec. 06+ is a DBW system and I believe there were a lot of sensor changes on this ECU change.
Old Jul 18, 2012 | 07:17 AM
AFs2k's Avatar
Well, I know '06-'09 is DBW. Are you saying that because the ECU changed they would change the sensor? Are you thinking freqs wise or just the wiring pins/connector?
That could be, but I'm thinking they have to be the same freqs... the short blocks are 99% the same. (difference is the crank position wheel)
Hell, if one is more sensitive, I'd like to run that one for added safty. DO I even need to care if I'll be running a stand alone?
Old Jul 18, 2012 | 07:28 AM
Suzuka_Joe's Avatar
brandon, use the knock sensor that matches what ecu your using. hell, if you have AEM alot of times the knock sensor is turned off..
Old Jul 18, 2012 | 08:53 AM
AFs2k's Avatar
Really Joe? Hell, was yours turned off? How will it be able to sense for knock if there is no sensor... *mind blown*
I will be running EMS v2 and e85 when I get the engine put in the car.
Old Jul 18, 2012 | 07:30 PM
rob-2's Avatar
I think they both detect knock, no more and no less than a different model.
I believe, if memory serves me there are different sensors be it connection or spec with the DBW system. Don't quote me on this but I would strongly advise sticking with the one that goes with your ecu.
Old Jul 19, 2012 | 05:26 AM
AFs2k's Avatar
Knock sensors have different freq ranges they are sensitve to. If you were to take one from a another engine, like a big V8, it would not work because the V8 will knock at a different freq and has been tuned from the factory to display knock when it hears those certain freqs.
Alos, the stock ecu plays no factor here. I will be using an AEM EMS v2.
I'm putting an '06-'09 short block in an '05. The only thing I can think of that would really change is the pins connectors for the wiring harness. The sensors have to detect the same freqs...
Old Jul 19, 2012 | 12:02 PM
rob-2's Avatar
The ap2 motor is unchanged 04-09. So I would not expect different frequencies for 'knock' to be triggered. The only logical explanation is the ECU.
