Knocking noise help
Hello please i have engine noise after cold start and when is engine warm and i started few sec this noise on youtube link. Ap1 2002 140 000 km. Valve clearance is good, tct oem new.
https://youtube.com/shorts/w8VHpTBnAiA?feature=share
only after start.
only after start.
Does it make the noise when you rev the engine? I have seen that same noise be the rod bearings. The best way to find out would be to get an oil analysis done on the car. Drain the oil and see if you have any metal shavings while you are in the process of getting the oil sample. I would also run a compression test.
Typically I would not jump to this suggestion right away but it seems like you replaced a lot of parts already in hopes to fix this noise.
when I rev the engine everything is ok. it only does it when idling. when I warm up the engine everything is ok. if I turn off the engine and wait 5 minutes, then after starting it clicks for a few seconds. if I turn off the engine and immediately start it again, it's ok. only when I wait a while does it make noises
