Knuckle, tie bar replacement
Old Mar 25, 2006 | 06:31 AM
mistaXs2000's Avatar
Default Knuckle, tie bar replacement
Problem:
Hit curb , Honda says passenger side rear knuckle is bent,(dont look bent ) not bad but that
Old Mar 25, 2006 | 07:17 AM
hondamanwill's Avatar
I would take it some place or remove it and take it to a machine shop and have them press it out. If not I have a speacial tool called the hub tammer, and if you live in Cali I could help.
Good Luck Will414-218-1420
Old Mar 25, 2006 | 07:37 AM
efthimios's Avatar
Originally Posted by mistaXs2000,Mar 25 2006, 10:31 AM
Honda says that i messed up my rear Knuckle, how do you replace it and what is it?....some people say it's also known as a tie bar.... i am not the best mechanic,(i think i can thou ) can i do this or should i take it to Honda
if it is the rear tie bar....I swapped mine with a Spoon one, Hardtopguy sells Comptech rear tie bars for $140....it's 10 minute swap...get under the car, pull out the bolts holding the oem one (which is about a 1.5' (something like that) long and is u-shaped....the after market ones are typically solid
Old Mar 25, 2006 | 07:43 AM
SC_Highlander's Avatar
It wouldn't be a tie BAR, but a tie ROD. The tie rod is forward of the control arms and is used to set the toe for the tire.
Old Mar 25, 2006 | 10:23 AM
ok....before i get down there and start ripping things out... can u guys please give a little bit of instruction on want to remove and tips and what to put back
bolts to remove and how many and location...?
any pics of the "tie ROD" "Knuckle"
Old Mar 25, 2006 | 11:48 AM
RedY2KS2k's Avatar
Here's the source for everything you need to know:
http://www.helminc.com/helm/Result.asp?Sty...FBCKKH94ADM77KB
Old Mar 25, 2006 | 02:13 PM
well thanks for the help RedY2KS2k,thanks for finding the site...but i dont want to spend money($75 )on a manual when i am just going to do this once...can anyone help me with the removal and install, what and how many bolts to remove
i am running away from
http://www.helminc.com/helm/Result.a...BCKKH94ADM77KB
Old Mar 26, 2006 | 07:29 AM
anyone got some ideas.. on repair procedure for the tie rod?
Sylvain2000
Jul 18, 2016 03:28 AM
gir89
Oct 25, 2015 04:59 PM
jmsimpo
Sep 27, 2014 11:33 AM
freescopesdad
Jan 8, 2008 05:03 PM
djvtecs2k
Jul 14, 2002 09:57 AM
