Koni yellow install.
Old Jul 24, 2005 | 08:38 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Default Koni yellow install.
I'm currently running KG/mm Supersport springs on stock shocks.
I want to replace stock shocks,with Koni Yellow.
I would like to run the front Koni on the lower perch,to get an additional 0.5 inch drop in the front,while leaving the rear Koni on the higher perch,in order to get a little rake.(1/2 inch)
First question:
1-)Can I do that,is it O.K.to do it?
2-)Someone told me,the Koni will have to be modified to fit the KG/mm,something like drilling a 12mm.hole in the pillow block,I dont understand,please explain.(is this mod.(drillling),for both front and rear,is it only to install on lower perch.Please clarify if possible.
What and where do I have do drill exactly?
Search function is down.
Looked in FAQ.but it only says you have to enlarge dust cover hole;is that the 12mm.drilling?
Thanks.
Emil.
Old Jul 24, 2005 | 11:35 AM
WtbS2k's Avatar
I will try to explain my best here.
You should set all four corners on lower perch since they don't give you too much drop on the rear anyways. if you put front on lower and rear on upper, rear will be too high i guess..
You will need to make the hole bigger in order to put the konis through. it's not that hard, but it takes a little time. You have to have right tools to do this, a power drill is what you need.
Hope this helps.
And you should of bought the whole set up from me, then you don't have to worry about the install
Old Jul 24, 2005 | 01:57 PM
Hope this helps.
Gee,did'nt know you had Koni yellow,with the KG.
Same condition as the KG?
If so,send them in,you have my address.(your price is mine)
Emil.
Old Jul 24, 2005 | 04:27 PM
WtbS2k's Avatar
Emil.
Yea, i had konis with KGMMs, but i broke them up to let you have the springs.
Konis were sold a few days ago
Old Jul 24, 2005 | 07:58 PM
So KG and Koni is a good set-up?
I was under the impression that Koni were a direct bolt;what modification does
it involve?
How much did you sell your Koni ?
Know where i can get some,and what would the best price be?
The mechanic who installed the springs,told me it was unsafe to run OEM shockswith them!
Old Jul 25, 2005 | 07:02 AM
milkbubble's Avatar
https://www.s2ki.com/forums/index.php?showtopic=303417
Nside
Jun 17, 2014 01:50 PM
magic tofu
Dec 12, 2012 07:41 PM
freds20002002
Feb 7, 2009 12:39 PM
JimmyB
Apr 6, 2008 07:11 AM
Emil St-Hilaire
May 23, 2005 02:00 PM
