Koni Yellow shocks...
Old May 14, 2002 | 01:46 PM
chungtaho0918's Avatar
Default Koni Yellow shocks...
Did anyone try Koni Yellow for s2k?
how was it compare to coil-over?
and what spring that you have to go with the Koni Yellow?
Old May 15, 2002 | 04:26 AM
cjb80's Avatar
You can use a stock spring, or a race spring. Ground control makes a collar for the Konis which will make them height adjustable, also they sell the kit with an Eibach spring I believe. This would be a good affordable setup in my opinion.
I have Koni yellows on my Civic SI and it's very nice, I like it alot. Definetly a better ride than stock, and handles great.
Chris
Old May 15, 2002 | 09:44 AM
currently I have km/mm racing spring on my s2k...
do they work well with Koni shocks..
I am thinking about changing shocks only or go to coil-over.....but to me coil-over seems a bit wasting money if I dun go on track often right?
Old May 15, 2002 | 10:49 AM
cjb80's Avatar
Currently I have stock suspension on my s2000, so take my advice with a grain of salt.
You should be able to run the kg/mm springs with the koni shock without a problem. The koni yellows are made tow ork with the stock springs or race springs. The kg/mm springs are meant to be stock replacments. Using that logic, they should work just fine, and that's how it works with my koni yellows on my Civic.
I believe that the S2000 koni yellows only have one perch for the springs, so if you used the kg/mm springs with the koni yellows then you would still maintain the same height as you currently have, but you'd have the stiffness adjustability.
On a completely seperate note, I can get you koni yellows for an awesome price! Let me know if you want a set.
Chris
Old May 15, 2002 | 11:58 AM
What's your price for Koni Yellow?
jsalicru
Mar 12, 2012 12:58 AM
zeroptzero
Aug 13, 2011 12:47 PM
02_s2k
Mar 6, 2011 02:23 AM
geminis2k
Aug 9, 2005 01:29 PM
shogun
Jun 9, 2003 08:29 PM
