S2000 suspension options
Old Aug 9, 2005 | 11:24 AM
geminis2k's Avatar
Default S2000 suspension options
Well, I had KG/MM race springs on my stock shocks for about 30k miles - Needless to say the shocks took a beating and now I need to replace them, they're on OEM springs atm as well
Is spending $1000.00+ really necessary?
I would like a full coil over setup like the Tein's but wouldn't something like springs for a drop and Koni yellow's do for daily driving?
How big a difference is there between the two?
Old Aug 9, 2005 | 11:28 AM
240sxer's Avatar
if you have to ask, the coilovers are probably a little much.
for daily and light spirted drives, spring/shocks would be more then enough to quinch your thirst, you also save a pretty penny going this route.
Wisconsin S2k's Avatar
moving to S2000talk. general product questions go there.
Old Aug 9, 2005 | 12:38 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
I just wanted to drop the car a little,for good looks,and improve handling at the same time(spirited street driving+3-4 track days/year).
Went with Kg/mm sports+Koni yellow.
Nice drop,+/-1",much better handling,and a little stiffer ride.
Old Aug 9, 2005 | 01:29 PM
esracer's Avatar
one thing you might want to keep in mind, I think that a spring and koni shock setup is around $800 for everything new, when you're spending that much you may as well spring for the little extra for a used set of tein coil overs.
02_s2k
Mar 6, 2011 02:23 AM
SSSS2222KKKK
Jun 3, 2008 12:58 AM
notyourfriend
Jan 5, 2007 06:02 AM
ninja.s2k
Nov 10, 2004 07:23 AM
chungtaho0918
May 15, 2002 11:58 AM
