koyo radiator problem
Old Jun 19, 2007 | 09:49 PM
s2kballin's Avatar
Default koyo radiator problem
i just installed a new koyo radiator i was on the freeway and the temp went up to 4 bars i put the heater on and the temp droped when we put it on the oem radiator cap was not fitting right why is the temp going up.
Old Jun 19, 2007 | 09:54 PM
s2k dre's Avatar
just have to bleed the air out of the system.
Old Jun 19, 2007 | 09:57 PM
s2kballin's Avatar
how do i do that? i'm new at this diy things
Old Jun 19, 2007 | 10:16 PM
s2k dre's Avatar
let it idle untill the thermostat opens,and then add more coolant, and there is a bleeder screw that u can take out and when coolant comes out of it then all the air is out. s2000 is a pain in the ass to bleed. U just got to keep tryin
Old Jun 19, 2007 | 10:17 PM
heresnowhy's Avatar
there is a bleeder bolt at the right front of your valve cover intake manifold side.
with the engine running, loosen the the screw very slow and let the coolant bubble out until there is a steady stream with no bubbles. Make sure the car is up to temp (fan cycled a couple times). It actually looks more like a bolt with a nipple or hole in the center of it.
Old Jun 19, 2007 | 10:22 PM
s2kballin's Avatar
thanks you guys i'll make sure to do that.
Old Jun 19, 2007 | 10:27 PM
markS2kcU's Avatar
If you are using the oem radiator cap off your honda on the koyo it is the WRONG cap to use, you will need a new one, do a search on koyo and it will tell you which type to use, I can't remember off the top of my head.
Quick search says you need a Type F cap, think the oem is a Type D.
Also keep an eye on your fan switch if you didn't put a new rubber seal on it, they are prone to leaking there.
Old Jun 20, 2007 | 01:34 AM
freshdrivewrx's Avatar
[QUOTE=mark_m,Jun 19 2007, 10:27 PM] If you are using the oem radiator cap off your honda on the koyo it is the WRONG cap to use, you will need a new one, do a search on koyo and it will tell you which type to use, I can't remember off the top of my head.
Old Jun 20, 2007 | 01:40 AM
markS2kcU's Avatar
Yeah It might do, I've got the spoon cap.
All I know is oem cap is the WRONG cap for the Koyo.
Old Jun 20, 2007 | 10:31 PM
s2kballin's Avatar
where is the bleeding bolt at i can't find it?
