Originally Posted by 305AP1
(Post 23405801)
I literally just purchased a 2007 f22c short block from my local dealer..
here it is in my living room |
Originally Posted by Aurex
(Post 23410994)
here it is in my living room It's related to this found in the original post...
Originally Posted by willrask
(Post 23403560)
The S2000 crowd’s engine options have changed recently. We can no longer buy a replacement short block or long block from the factory.
luckily we have jordanskartell and billman.
Originally Posted by bgoetz
(Post 23410929)
here it is in my living room http://i35.photobucket.com/albums/d1...ps96a703bf.jpg |
Originally Posted by darcyw
(Post 23410444)
here it is in my living room http://i35.photobucket.com/albums/d1...ps96a703bf.jpg darcy |
Its my understanding the AP1 block is no longer available from Honda, but the AP2 is. Billman reported this recently.
I bet the engine build, all told, cost more than the new block from Honda would have. I would be really pissed at whoever told you blocks are no longer available, and a little at myself for not checking personally. Live and learn. Thanks fpr sharing your expierence with community, so we can all benefit from this info. Your post was remarkably free of animosity. I would not be able to have the same restraint. |
All AP1 and 04-05 blocks are no longer available from Honda. You can still get the 06+ block though, but in order to make it work in a 2000-2005, you must change out the crank pulse plate to the 00-05 version. :tipwink:
What does that entail Jordan? Is it difficult/expensive?
Just pull the one off your existing motor and swap it on. Chances are, you'd already be swapping everything over so the level of difficulty for that task should be easy.
Originally Posted by Mexs2k
(Post 23404715)
That really sucks man. And I bet all that work really cost an arm and a leg. Did they give u any explanation or at least try to make it right. That's b.s..
I talked to Laskey about the leaking head gasket. His suggestion was to retorque the head. He did not offer any assistance. After hearing his comment about retorque it told me he was not interested in stepping back into it and if he really thought retorque was a solution, turn and run as fast as you can. |
