Laskey Racing Engines Poor Performer
Old 11-19-2014, 08:06 AM
Aurex's Avatar
Originally Posted by 305AP1
I literally just purchased a 2007 f22c short block from my local dealer..
here it is in my living room
Is this related to a built motor failure?
Old 11-19-2014, 08:18 AM
yamahaSHO's Avatar
It's related to this found in the original post...
Originally Posted by willrask
The S2000 crowd’s engine options have changed recently. We can no longer buy a replacement short block or long block from the factory.
Old 11-19-2014, 08:52 AM
iamxpl's Avatar
luckily we have jordanskartell and billman.
Old 11-20-2014, 07:38 AM
305AP1's Avatar
How much did that set you back?
2900$
Old 11-20-2014, 07:39 AM
305AP1's Avatar
that's pure automotive porn. Thanks for the picture.
darcy
No problem lol
Old 11-20-2014, 08:04 AM
Car Analogy's Avatar
Received 1,355 Likes on 1,021 Posts
Its my understanding the AP1 block is no longer available from Honda, but the AP2 is. Billman reported this recently.
I bet the engine build, all told, cost more than the new block from Honda would have. I would be really pissed at whoever told you blocks are no longer available, and a little at myself for not checking personally. Live and learn.
Thanks fpr sharing your expierence with community, so we can all benefit from this info. Your post was remarkably free of animosity. I would not be able to have the same restraint.
Old 11-20-2014, 08:12 AM
MM3Kwolik's Avatar
All AP1 and 04-05 blocks are no longer available from Honda. You can still get the 06+ block though, but in order to make it work in a 2000-2005, you must change out the crank pulse plate to the 00-05 version.
Old 11-20-2014, 09:27 AM
bgoetz's Avatar
What does that entail Jordan? Is it difficult/expensive?
Old 11-20-2014, 10:12 AM
yamahaSHO's Avatar
Just pull the one off your existing motor and swap it on. Chances are, you'd already be swapping everything over so the level of difficulty for that task should be easy.
Old 11-20-2014, 06:50 PM
willrask's Avatar
Originally Posted by Mexs2k
That really sucks man. And I bet all that work really cost an arm and a leg. Did they give u any explanation or at least try to make it right. That's b.s..
I talked to Laskey about the leaking head gasket. His suggestion was to retorque the head. He did not offer any assistance. After hearing his comment about retorque it told me he was not interested in stepping back into it and if he really thought retorque was a solution, turn and run as fast as you can.
Quick Reply: Laskey Racing Engines Poor Performer
