Leaf Blower (Electric Supercharger)
Everything works better with more...how about 3 or 4 gas leaf blowers mounted in the front and fueled off the tank...hmmm I'll bet it would sound nice.....
fltsfshr
great ideas start somewhere....how about a quick shot precooler or a cold gas fast intercooler temperature reducer....
fltsfshr
I love threads like this (seriously, cuz it gets you thinking)
Consider PSI over the rev range - At 0 RPM you may get some boost.
At 9k, even the the biggest "backpack style" gas powered blowers will "get you even", meaning rather than the engine under vacuum, you'll get a whopping 0 psi of boost.
9000 rpm / 2 = 4500 intake cycles per minute
2 liters = 0.07062933 ft^3
4500*0.07062933 = 318 ft^3 per minute
At least you won't have to worry about putting a BOV or wastegate on your leaf blower
forget leaf blowers . . . I want to know the first person to jam a hydraulic accumulator in the s2k - just imagine adding 200 ft*lb (or more!!) of torque off the line AND getting better gas mileage
Mmmmm .... hydraulic accumulator.
I bought a leaf blower , an extension cord, and a power inverter. I tried it but the most powerful inverter I could find put out 110volts. The blower required 120volts. I tried it but it just made a "grrrrrrrrrrr" sound. I'll put this project on the back burner until I can find a more powerful inverter or find some other way to overcome this obsticle.
I suspect that the problem isn't the voltage, but the available amperage from the inverter. Check the current draw (amp rating) on the leaf blower and the available amperage from the inverter.
As I remember it, most electric leaf blowers draw quite a bit of current and many 12 VDC - 110 VAC inverters don't deliver much. And keep in mind that 10 amps out at 110-120 VAC will require quite a bit more than 10 amps in at 12 VDC.
