Leak, is this normal on a 4 months old AP2?
Recently, I just did my first oil change and found out these stains on my engine. Is this normal? Or I have to get this warranteed before future problems? Thanks for any help. Engine is bone stock with about 5000+ miles.
I had a slight leak in that exact area on my '05 at about the 2 month mark. I wiped it off and never had anything return. I've seen numerous other posts - not sure what causes it, but it doesn't appear to be abnormal.
It's a non-pressurized oil seepage from between the head gasket and timing chain case. It's fairly common, what you are seeing is as bad as it gets. Spray it with some brake cleaner and don't worry.
The only repair option is to replace the head gasket.
