Left headlights on, car not starting
Old Mar 6, 2016 | 02:48 PM
fastb4ck's Avatar
Default Left headlights on, car not starting
So I forgot to turn off my headlights, parked went inside.
Come back out in 3 hours, car won't start, had to open door manually with key.
When I turned the key and pressed the start button, nothing happened
tried to jump the car, now the dash lights come on but the car just keeps clicking, won't turn over, everything else works, lights, car unlocks with button etc.
I left it there for like 10 minutes connected to my other car with jumper cables, tried to start it again and it's the same, dash lights come on, and just clicks
Do i have to leave it there for longer since the batter is so small?
Old Mar 6, 2016 | 03:06 PM
chefs2000's Avatar
Get a new battery
Old Mar 6, 2016 | 03:30 PM
fastb4ck's Avatar
Originally Posted by chefs2000
Get a new battery
Really? just from that
It showed no signs of being a weak/struggling battery before this.
Old Mar 6, 2016 | 03:38 PM
Utah S2K's Avatar
The donor car is running right? If not try starting it before turning yours over.
Utah
Old Mar 6, 2016 | 03:41 PM
fastb4ck's Avatar
Utah
Yeah donor car was running
Old Mar 6, 2016 | 03:55 PM
MSTSH80's Avatar
Did you hold the rpms up on the donor car? hold it at 3k and try it. Larger trucks and suvs usually work better also.
Another option is buy a trickle charger, its best to fully recharge a battery after its been run down.
Old Mar 6, 2016 | 03:58 PM
afzan's Avatar
Try another car with a larger battery/alternator?
Our cars seem to need more power to start vs other 4bangers (because of the higher compression?)
Old Mar 6, 2016 | 04:18 PM
fastb4ck's Avatar
I had to get somewhere, so I won't be able to do it today.
I'll try these tomorrow
Thanks guys
Old Mar 6, 2016 | 04:30 PM
zeroptzero's Avatar
What kind of battery it is ?, some types of batteries like AGM's don't recover well once they are allowed to fully discharge and they require a different procedure to bring them back to life.
Old Mar 6, 2016 | 04:37 PM
fastb4ck's Avatar
It's a duralast yellow top I believe
