License Plate Lights?
Are you trying to replace your license plate light? Do you see the plate light assembly? The light assembly is attached to the rear bumper above the license plate. Use a vety small screw driver and push the assemble forward (toward the front of the car). A hole will become visible on each side. Insert the small screwdriver in that hole to release each side of the assembly from the bumper. Remove the lense to expose the bulb.
or you an just squeeze both side of the clear housing and pull it out.
the second time you can pull it out in 2 seconds!
<--just replaced the old LED light for some awesome brighter LED light =P
pakman08
Dec 21, 2009 10:14 AM
