Limp Mode
Old Jun 3, 2018 | 03:14 PM
kjonesy203's Avatar
Default Limp Mode
I removed my valve cover to paint it and i think i might have shifted the cam angles because my check engine light is on and car wont go past 3k rpms. Any links on how to “reset” my valves or cams not sure the correct words to use
Old Jun 3, 2018 | 05:57 PM
jts09's Avatar
You can't "shift the cam angles" by just removing the valve cover. Are you sure that you reconnected everything on the valve cover? There's a sensor to allow the ECU to work properly that "senses" TDC (Top Dead Center). I believe that AP1's have 2 of these sensors and the AP2 has 1 (someone correct me on the AP1 if that's not the case). I own an AP2 and the TDC sensor is at the back of the valve cover.
Old Jun 3, 2018 | 09:38 PM
flanders's Avatar
2000-2005 has two sensors and 2006 and up has only one.
Old Jun 4, 2018 | 06:55 AM
kjonesy203's Avatar
Originally Posted by jts09
You can't "shift the cam angles" by just removing the valve cover. Are you sure that you reconnected everything on the valve cover? There a sensor to allow the ECU to work properly that "senses" TDC (Top Dead Center). I believe that AP1's have 2 of these sensors and the AP2 has 1 (someone correct me on the AP1 if that's not the case). I own an AP2 and the TDC sensor is at the back of the valve cover.
Both sensors are connected. I figured when removing it i mightve hit one becuase it was a slight struggle lifting the back of the cover off. I have an 04. One sensor on the left and one on the back right behind the oil cap
Old Jun 4, 2018 | 08:05 AM
flanders's Avatar
Check the error code.
Old Jun 4, 2018 | 08:15 AM
kjonesy203's Avatar
ok ill check when i get home frome work, gotta get an obd2 scanner
nshoes
Apr 27, 2018 10:24 AM
seoul2k
Nov 26, 2010 04:37 AM
GpWaP1 s2k
Jul 28, 2010 11:37 AM
Kyushin
Feb 20, 2010 07:28 AM
YuriArts
Oct 14, 2007 01:05 PM
