Link to diy timing chain replacement?
A PM from you in May: " Using ANY bolt-retraction style tensioner with a new chain will over tighten it. It will put the equivalent of 100k on the chain in 2000 miles. I also recommend putting 1000 miles on the new chain using an OEM tensioner, before installing mine." Maybe this is because I'm not installing a new guide setup?
Chain stretch or whining noise can be a result of improper installation of the Ballade TCT or any TCT. I use a Ballade TCT in my S/C S2000 and will use a Toda TCT in my NA S2000.
To 912S2K, LHT Performance is near you(150 miles away) if you run into trouble. Did you contact Ballade about the TCT? They would probably do a replacement. Did you oil the O rings and turn the crack pulley until minimal force was required to push the TCT in?
Ok good. I almost s*** myself thinking I had to go buy an OEM TCT.
I have not removed your TCT yet. Will I need to reinsert the 5mm bolt to remove your TCT from the engine?
Hmm so I'll need to wiggle it out on each side equally.
Nothing like a fun game of hide and seek...
Are you WPC treating the whole gear set? I'm considering doing that to mine to help extend the life of them. Do you know what the average turnaround time is?
I'm going to WPC treat the whole gear set. Pricing for each gear/sprocket is about $30 each. Turn around time is about 2-4 business days(M-F). I don't think WPC uses USPS priority mail for return shipments If you want to save on shipping costs, I would ask if they do, if not supply your own return shipping label with the parts you send in.
