Link to diy timing chain replacement?
Old Jan 6, 2017 | 04:33 PM
Mexs2k's Avatar
Default Link to diy timing chain replacement?
Just wondering if anyone has a link to a diy timing replacement or setting timing. Not that I need the work done but I wanted to know how it's done just in case for future reference. I looked on the sticky's and didn't find anything, I looked on YouTube and couldn't find anything. I'm just trying to learn different aspects of this motor.
Old Jan 6, 2017 | 04:51 PM
windhund116's Avatar
Honda made engines usually do not need routine timing chain replacement. AFAIK.
Old Jan 6, 2017 | 10:12 PM
Mexs2k's Avatar
Yeah I know but since I kind of already know how to rebuild b-series engines and feel confortable with them, my next step is to learn the s2000 engine some more
Old Jan 7, 2017 | 02:38 AM
Jaspah's Avatar
The chain is driven by a small sprocket on the crankshaft, and connects to the idler gear which drives both camshafts.
The TCT (timing chain tensioner) puts pressure on the guide to keep the chain straight.
When you remove the timing chain cover, loosen the TCT, there is enough room on the chain to remove the upper sprocket.
The lower sprocket also drives the oilpump via a small chain. I'm not sure you have to remove this one in order to remove the timing chain. I do think so
When mounting, timing the sprockets is pretty easy, there are some diy's on this forum
Old Jan 7, 2017 | 05:34 AM
zeroptzero's Avatar
best to pick up a shop manual if you want to tackle something like that, lots of little details that are part of the project including the timing mark alignment. I have not seen a DIY on this.
Old Jan 7, 2017 | 11:13 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The book calls for cylinder head removal and timing cover removal.
It can be done by oil pan removal and timing cover removal instead. Save major time.
Old Jun 27, 2018 | 03:29 PM
912S2k's Avatar
I am going to need to replace my timing chain. The Ballad Sports TCT stretched my chain and I can hear it whining while driving the car. Will I need to replace the guides as well?
Old Jun 27, 2018 | 03:30 PM
912S2k's Avatar
Can I remove the timing chain without removing the oil pump chain?
Old Jun 27, 2018 | 06:09 PM
xDoodles's Avatar
Yes you can without removing the oil pump chain and get rid of that TCT and buy Billman's. You're lucky it hasn't caused any significant damage yet.
Old Jun 28, 2018 | 03:53 AM
912S2k's Avatar
I did but unfortunately not before the chain was permanently stretched.
