Liquid gasket on head
Old Oct 7, 2009 | 09:37 AM
booski's Avatar
Default Liquid gasket on head
So i'm finally about to put my head back together and i need some high temp liquid gasket.
it goes around the timing chain housing.
i looked on alldata it just says to put it on top of the head gasket, but when i removed the head, there was liquid gasket on the head and the block??
so i guess i'll play it safe and do both again.
just looking for some input.
also, is any high temp liquid gasket okay?
i dont have a local honda dealership :/
Old Oct 7, 2009 | 09:55 AM
Stratocaster's Avatar
You just need "Hondabond" around the timing chain opening. A thin bead just inside the headgasket around just that hole.
Any RTV will work just fine.
I assume you have a OEM service manual? If not, go get one.
Old Oct 7, 2009 | 10:15 AM
booski's Avatar
i know where it goes around, but does it go block and on top of gasket?
and i'm using alldatapro, which usually is dead on with manual.
Old Oct 7, 2009 | 11:35 AM
You would not be asking this question if you used the OEM service manaul. So dead on or not, there is a gap.
Here is the anwser to your question.
LAE
Nov 25, 2018 04:45 PM
Jdmjeckjeck
Aug 29, 2018 07:20 PM
slociviccoupe
Mar 26, 2009 04:43 PM
krazik
Jun 18, 2004 02:45 PM
Luis
Oct 29, 2000 09:03 AM
