Looking for: DIY O2 Sensor
Old Apr 29, 2005 | 08:18 PM
Costas's Avatar
Default Looking for: DIY O2 Sensor
I've tried using the search for about half an hour but can't seem to find the thread. It was basically a thread that had pics on how to modify the sensor that goes into the test pipe in order to get rid of the CEL. What it did was just move the sensor a little further back so that it wouldn't detect the fumes as much.
Anyone happen to have a link to it?
Old Apr 29, 2005 | 09:08 PM
xviper's Avatar
https://www.s2ki.com/forums/index.php?showtopic=229959
This and many other key threads are listed in the FAQs at the top of Technical. Have a look sometime.
Old Apr 29, 2005 | 10:35 PM
Costas's Avatar
Thanks!
Old Apr 29, 2005 | 10:40 PM
Ooalloems2koO's Avatar
Is this CEL related to secondary 02 sensor??
Old Apr 30, 2005 | 07:32 AM
xviper's Avatar
The CEL light can be triggered by ANY of dozens upon dozens of faults in this car. The sec. O2 is only one.
Old May 4, 2005 | 04:08 PM
is this case.... the CEL is related to secondary O2 sensor right?
Old May 4, 2005 | 06:18 PM
xviper's Avatar
If you install a test pipe and just plug in the O2 sensor directly, then yes, it will most likely throw a CEL.
Old May 4, 2005 | 09:54 PM
how about my 02 sensor broke ( i see a bare wires but not disconnected and this is WHY it is throwing a CEL)
would this still work??
Old May 5, 2005 | 05:36 AM
Ztec's Avatar
Is your sensor in a stock cat or a test pipe? You should not have any bare wires, Did the sensor get hit - You might need to replace your sensor!
Old May 5, 2005 | 06:18 AM
xviper's Avatar
No, you have an O2 sensor that isn't "talking" to the ECU due to the disconnected wires. Until you get a working O2 sensor, the CEL will remain.
O2 simulators trick the ECU into seeing a "normal" condition. An electronic one will work to eliminate your CEL because it will "talk" to the ECU. It's just that it will tell the ECU a lie.
A "Mechanical" simulator is just that - a mechanical device. You still have to have a working O2 sensor (which you don't).
cmc600rr
Oct 5, 2011 06:35 AM
tkeyyy
24
May 10, 2011 07:15 AM
Imarriedmys2k
Oct 31, 2010 04:50 AM
JLuda
Jun 13, 2007 07:28 PM
