which decat will not throw a CEL Code
Old Oct 30, 2010 | 10:12 AM
Imarriedmys2k's Avatar
Default which decat will not throw a CEL Code
hi guys.. looking to buy a decat for my s, however i dont want no engine management light showing. Is there a branded decat out there with an o2 hole available that will not throw a code? there are a couple i have seen on ebay but state that a o2 simluator may be needed to prevent the cel light from popping up.??
Old Oct 31, 2010 | 12:57 AM
mattxx's Avatar
All you have to do is buy a decat with a O2 sensor threaded hole (which is almost all of them) and buy a O2 sensor adaptor. The adapter is a hollow threaded piece with male and female threads. You screw the adapter into the decat and screw the O2 sensor into the adapter. The adapter makes it so that the O2 sensor is not in the direct path of the exhaust. The sensor just reads clean air inside the adapter since the sensor is now outside of the decat.
Old Oct 31, 2010 | 01:02 AM
mattxx's Avatar
Just an example.
http://www.bigdaddiesgarage.com/straight-cel-fix.html
also called "o2 sensor bypass simulator"
http://www.thefind.com/cars/info-test-o2-sensor
http://www.hhoincar.com/o2-extender-extens...ell-test-pipe-2
Old Oct 31, 2010 | 03:41 AM
lovegroova's Avatar
How about using a Garage-R model? https://www.s2ki.com/forums/index.php?showtopic=790237 a fair few people have these with no CEL.
Old Oct 31, 2010 | 04:13 AM
iNTOXiCATiON's Avatar
Have got one myself with the antifouler however did throw up cel twice but after resetting its been fine after about 500miles no issue.
Old Oct 31, 2010 | 04:34 AM
Chad!'s Avatar
I have the GarageR one fitted to mine. Had it on for about 3-400 miles and so far so good. No CEL issues at all. I'd PM Rob at GarageR if I were you, nice bit of kit.
Chad.
Old Oct 31, 2010 | 04:50 AM
thanks for clearing that up guys! BIG THANK YOU! :-)
4x4 freak
Dec 2, 2015 10:08 PM
ViperASR
Jan 10, 2013 06:19 PM
cmc600rr
Oct 5, 2011 06:35 AM
phase_k
Sep 17, 2007 09:02 AM
JLuda
Jun 13, 2007 07:28 PM
