Looking for someone with P2138 code on 06+ to confirm a fix
Old Jun 8, 2017 | 07:27 AM
MemphiS2k's Avatar
Default Looking for someone with P2138 code on 06+ to try my fix and report back
Hey guys,
I recently had issues with rough driving at low rpms, especially on cold starts. The car finally threw a P2138 (accelerator position sensor). While waiting for the part to arrive via UPS, i decided to poke around on the broken one. I manually retracted the cable wheel a few time, the last of which I let it snap back at full speed. I did not drive the car right away. The next morning, the issue was gone. It has since driven perfect for several hundred miles this week. I'm hoping someone with the same code could give this a try to see if it's a valid fix before I try to document it on s2ki.
Old Jun 15, 2017 | 12:19 PM
MemphiS2k's Avatar
Nobody is having this issue right now? I can't be the only one.
Old Jun 16, 2017 | 08:09 AM
dpak's Avatar
same issue on my car 06 as well. Just had the code pop up last night and drove it in the morning and seems to be fine. what did you do to fix the issue?
Old Jun 18, 2017 | 12:14 PM
Slowcrash_101's Avatar
What do you want us to say, in your original post it sounded like the issue was resolved.
Old Jun 19, 2017 | 06:50 AM
MemphiS2k's Avatar
I want someone else to try the same thing to confirm if it's an actual fix before I write it up as an actual fix.
Old Jun 19, 2017 | 06:51 AM
MemphiS2k's Avatar
Try the above and clear the code. You can do an ECU reset as well, but I did not. Please report back if it was successful.
Old Jun 21, 2017 | 08:50 AM
dpak's Avatar
I tried the same thing. the cel popped back up once more but i have been good since then. seems like the sensor itself is going bad. ill leave it for now but if it pops up again i will just go ahead and replace the sensor.
Old Jun 21, 2017 | 09:51 AM
MemphiS2k's Avatar
Thanks for giving it a shot.
Old Aug 27, 2022 | 01:48 PM
georges's Avatar
(five years later) Didn't work for me. I previously replaced the sensor and that worked, but the problem is now back. Thanks for posting though.
Old Aug 27, 2022 | 03:29 PM
Car Analogy's Avatar
Never saw this post before. My guess is the snapping back helped knock free some build up on the potentiometer. But its unlikely to be a long term fix.
Honda only sells the entire throttle assembly, and it ain't cheap. Yet it seems only the electronic bit is only piece that ever goes bad.
Aftermarket sells this individual electronic piece. Dirt cheap. Its actually a part meant for a Pilot I think. Its not a perfect match, unfortunately. Requires very meticulous install. Balance between tripping position too low and too high.
I posted a diy thread on it a while back.
NeroS2k
Aug 31, 2012 10:02 AM
caleb2483
May 21, 2012 07:57 AM
miguel329
Apr 26, 2011 12:41 PM
mwong
Dec 4, 2009 07:26 AM
scors2
Sep 4, 2009 07:05 AM
