Loose handling
Originally Posted by k24accord' timestamp='1356016249' post='22221594
-My rear tires are slightly unevenly worn. it appears as if the rear right tire is right about at the wear bars while the rear left seems to be noticeably above the wear bar.
Thanks for your help!
If you had your location under your name, members could direct you to a proffesional to get your car sorted, and not some clown. That is what s2ki is all about.
Based on the current numbers, I strongly feel something is bent.
For my money, a *proper* alignment will have *some* negative camber to provide ultimate cornering grip. This is a reasonable sacrifice in the interest not only of performance, but also safety. This will give *some* asymmetric wear, of course, but in my experience decent street camber settings (for me, negative 1-2 degrees or so) don't cost you more than ~10-15% in terms of tire life. Toe-in will have a VASTLY more dramatic effect on tire life.
My generic street alignment recommendation that any shop should be willing to do (i.e., falls within "spec"):
Absolute minimum (closest to zero) toe front and rear within spec range (the stock AP1 spec range for rear toe goes WAY too high)
Maximum negative camber front and rear within spec
Caster within a tenth or two left/right, within spec range (I prefer it to also be minimized, but this is down to personal preference and usage)
I don't know what I did with the printout (currently in the middle of moving so who knows where the printout is lol) but I do remember the front caster number being 5.9 on each side. Don't remember the camber for the front/rear or the toe, but I do remember everything with the exception of the camber (since I'm lowered) being "in the green", which I now know is useless. I should note that the car did drive normal after the "in the green" alignment I had done, so I'm thinking a combo of the alignment being out of wack and the worn tires, but with the accident my paranoia kicks into full gear
Billman, would it be possible for something to be bent even if the car aligns into the accepted range?
Thanks man, I appreciate the help. Just trying to resolve it without blindly throwing money at it.
Finally got a chance to drive it down to have the alignment checked out (picture below). Car was put on the rack and immediately one of the techs noticed that the ride height was off drastically off. The driver front side, which was the side that was hit, sits a good inch and change or so lower. Never noticed it beforehand as I only drive the car s few times a week, but after looking at it on the rack, you can clearly tell the ride height difference. I'm on megan track adjustable coilovers and had the driver side front LCA replaced, so I'm thinking either the shop messed with the coilover before reinstalling it onto the new LCA, or it's blown or otherwise damaged from the accident.
I had had the car aligned a few months back, unaware of the ride height issue. At this point, I'm definitely thinking this is the root cause of the issues I've been having. Going to take a look at the offending coilover and see if it's blown or if it just needs to be readjusted and realigned accordingly.
Any thoughts?
Any thoughts?
