Lost compression from sitting?
Old Jul 22, 2023 | 12:59 PM
umair's Avatar
Default Lost compression from sitting?
I am looking to buy an engine for my s2000. It has under 10k miles and I confirmed it with a Vin check. A friend of mine bought it as a flood damage car. When he bought it it was running and he showed me a video. However one day before buying it , it stopped turning on. Upon buying the vehicle he ran a compression test and it was 230-240 across the board. This was in November. He ran a test this weekend and cylinder 1 and 3 came back to 160. Even at 160 the engine should still run. I'm going to help him do a leak down test as I am curious myself. Has anyone experienced anything like this?
thanks
Old Jul 22, 2023 | 01:12 PM
windhund116's Avatar
thanks
Collapsed or stuck piston rings?
Old Jul 22, 2023 | 03:00 PM
B serious's Avatar
Might just be a testing error. A leakdown will be more pointed. See if a big leakdown number follows the #3 cyl.
Unless the engine was sitting with water in the cylinder? Its not an iron cylinder, but the rings are steel. I think the valves are inconel and SS...so...probably water doesn't really affect them.
Old Jul 23, 2023 | 08:15 AM
Car Analogy's Avatar
My thought too. Various old school methods how to unstick.
Old Jul 23, 2023 | 09:55 AM
My Dad used to put a pint of auto transmission fluid in the engine oil (it's highly detergent). Run the car for like 20 minutes --- until it's been at operating temp for a while.
Then, drain. Replace with cheap oil. Run a couple hundred miles --- replace. Then, new oil and oil filter. Usually worked.
Old Jul 23, 2023 | 12:23 PM
umair's Avatar
Thanks for the replies guys. I am going to do a leak down test and a compression test this week. I'll keep you posted.
Old Jul 24, 2023 | 08:12 AM
Mr.Matchbox's Avatar
Valve seats in the head lightly corroded, therefore the valves dont seal as good as before?
Remember, some valves are allways open when you shut down the engine and connected to the atmosphere via the (Hopefully) not air thight exhaust.
Old Jul 24, 2023 | 11:48 AM
B serious's Avatar
Are the seats made from a ferrous material that is prone to rust, though? Or any material that is prone to corrosion just from atmosphere?
Old Jul 24, 2023 | 11:36 PM
I don know. But the Situation i have described is Possible and happend to engines. Anybody has a Cylinder head of a S2000 on the workbench and a magnet ready?
Old Jul 25, 2023 | 05:37 AM
starchland's Avatar
160. What were the other numbers? Was the same gauge used for both tests? If no the test is moot
