Lowering the compresion is worth
Originally posted by cjb80
Fuel pressure increases one psi for each pound of air pressure over ambient, and it pulls fuel pressure for each pound below ambient.
Chris
Chris
Chris that is you call a FMU, fuel management unit
Originally posted by demonderrick
just out of my criousity, as far as I could see, your setup without 550cc injector already could achieve 290 whp which few people on the board has done the dyno... or... am I wrong?
I did 275 whp, but I was runnig very very lean A/F 15:1. While I was NA I did 175 whp.
I am going with the 550cc and in the future with 8 psi to get 300 whp goal.
Originally posted by S2000_Europe
H9k
thanks for the page, I made a excel worksheet for the calculations.
Wesmaster ir a real example, hi is running 320 whp with:
550 cc
Aem FRP 1:1 ( what this mean? a relation between fuel preassure and boost?)
H9k
550 cc
It really depends on what dyno he used
we shouldn't just look at raw dyno number (at the wheel power) and should look at the engine power. The stock s2k engine power is 240hp in the US. The dynapack dyno gives reading of around 200hpatw. Therefore the drivetrain loss is only around 17% on the dynapack. That's around 374hp at the engine.BTW Most OZ tuners use dynodnamics, I think the drive train loss is aound 30%.
Do you know what dyno your tuner use? how much power train loss?
If you go 11psi, you won't make 320hp on the dynapack
I think you will make a lot more.Anyway, according to the calculator, which is only an estimate, Wes's duty cycle may be higher than 80%.
