manual tranny fluid
Old Mar 5, 2003 | 02:33 PM
s-duces's Avatar
Default manual tranny fluid
im changing my clutch and flywheel what kind of tranny fluid should i use? and should i also change my pressure plate also? thanks
jack
Old Mar 5, 2003 | 03:02 PM
boiler's Avatar
jack
YES to the pressure plate and don't forget the throw out bearing. If you are going to the trouble to tear it apart, it doesn't make any sense not to change ALL of the wear items while you are there. I speak from experience. A lot of people like to use Honda's MTF. Others use Redline or GM Synchromesh. The Honda MTF is probably the safest bet.
Bob
Old Mar 5, 2003 | 03:04 PM
cdelena's Avatar
You are gonna have a fresh mating surface with the new flywheel, the right way to do it is the PP too. Do a search on the MTF, there are many good choices including the Honda stuff.
s2kLi
May 27, 2011 09:33 AM
JL9000
Aug 31, 2004 03:45 PM
S2KNormR1
Jul 12, 2004 12:19 PM
Zonie
Nov 29, 2003 06:06 PM
dp2580
Feb 21, 2003 08:15 AM
