Map Light will not work
Old Oct 14, 2008 | 12:42 PM
racer_X_123's Avatar
Default Map Light will not work
Hello, the map light works when you unlock the car, open the door, and move the switch to the right(or left, whatever turns them both on) but it will not work if i push the little clicky buttons...
What is the issue here?
Old Oct 14, 2008 | 12:43 PM
senor_flojo's Avatar
From: All up in your inner tubes. Whatcha gonna do sucka?
user error
Old Oct 14, 2008 | 12:44 PM
I dont think so, i have tried the buttons with the switch in all positions...
If i am remebering correctly, it is left off, center door, and right on?
with it in the center, it should come on when i push either of the 2 buttons.
Old Oct 14, 2008 | 12:59 PM
Elistan's Avatar
Which little clicky buttons?
Old Oct 14, 2008 | 01:05 PM
the individual buttons to turn on either the left or right lamps seperate from each other.
Old Oct 14, 2008 | 01:20 PM
Elistan's Avatar
Oh! I see. Sorry, no idea what could be causing your issue.
Old Oct 15, 2008 | 07:37 AM
I dont understand what the problem is, everything else about the maplight works fine.
What could it be? I fuse somewhere?
Old Oct 15, 2008 | 02:03 PM
ahrmike's Avatar
i got the same prob man.
Old Oct 15, 2008 | 03:53 PM
captain_pants's Avatar
Me too. Mine actually flickered for a while and then stopped working altogether. It still functions normally when the doors open or you switch the light on.
Old Oct 15, 2008 | 04:30 PM
2000silvers2k's Avatar
i got a similiar problem, If I put mine in the door position, they do not go off, ever. so im stuck with not having them when i get in/out of the car in the dark. kinda annoying.
i still think it may be user error though
