Map Sensor Question
Old Feb 21, 2008 | 04:59 PM
albe's Avatar
Default Map Sensor Question
hey is it fine if i use a 98 prelude map senor for the TB for a bit till i get the s2000 one? will anything go wrong?
Old Feb 21, 2008 | 05:28 PM
S-Turn AP1's Avatar
I believe alot of newer hondas use the same map sensor ( part # ), Its should fit in ok and the worst that could happen would be the car wouldn't run or run bad. In that case i would not contiue to use it.
Old Feb 21, 2008 | 05:42 PM
courantcom's Avatar
Yes. You would know right away if the sensor is no bueno. You'll get a check engine light, and it'll idle like it's got a lumpy cam in it.
Old Feb 21, 2008 | 06:04 PM
albe's Avatar
i havnt got any check engine light on yet and it doesnt idle weird. i try doing the map whack but it didnt work on the s2000 sensor.
ScienceofSpeed
Mar 7, 2010 07:26 PM
Putney
Jun 13, 2008 04:28 AM
silencertk
Jun 28, 2006 07:17 PM
JohnE
Aug 10, 2005 08:20 AM
MrV
Dec 5, 2004 06:12 AM
