Master cyl replace or fix?
Old Mar 2, 2010 | 07:40 PM
black2000's Avatar
Default Master cyl replace or fix?
got clutch/brake fluid in my carpet under the clutch pedal...
is this a sure sign of needing to replace the master cyl or is there a fix (like a new rubber seal) that can be done?
Old Mar 2, 2010 | 08:04 PM
hypforlife32's Avatar
you will have to replace it. i just replaced mine and i have bad luck and got a faulty one that started leaking again 1 day after i put it in. clutch felt great for awhile then it felt terrible a day later. and was leaking. pepboys has them pretty cheap like 70 bucks or so
Old Mar 3, 2010 | 12:14 AM
nv_blitz's Avatar
pick up an omni power one, its an upgrade over the stock makes the clutch feel better and allows for quicker shifts
Old Mar 3, 2010 | 01:27 AM
turbo_slug's Avatar
please explain why you think it feels better...
Old Mar 3, 2010 | 04:19 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Omni-clutch master is garbage.
You don't need a new master either.
95% of all s2k clutch master cyls leak, from dirty fluid. Everyone can go look right now
Just change your fluid now, and every 5k miles, and the leak will stop. Guaranteed.
Old Mar 3, 2010 | 05:32 AM
dales2000's Avatar
this maybe a stupid question but how does the fluid get dirty so quickly?
Old Mar 3, 2010 | 05:43 AM
x1...i just replace mine and it start leaking again recentley...how does the fluid get dirty so easy?
Old Mar 3, 2010 | 05:44 AM
estooki's Avatar
i say change the fluid and if it does it again you need to replace the master cyl
Old Mar 3, 2010 | 05:48 AM
Saki GT's Avatar
Buy a new OEM CMC from CFL Honda - Its like $78 and comes with a bottle of DOT3 - great guy to buy from.
http://www.cflhonda.com/splash/index.cfm?siteid=215502
Old Mar 3, 2010 | 05:51 AM
Saki GT's Avatar
I think after time, the seals just corrode. The OP has a 00 s, you have an 01, and from what I've read here, CMCs can go bad in as little as three years.
Fwiw, I just replaced mine at 6 yrs old. I first flushed the fluid, but it was still leaking, with black build up at the plunger, which I took to be disintegrating rubber mixed with brake fluid. Ymmv.
