Master Cylinder is Leaking
Old Mar 7, 2006 | 01:36 PM
JasonX82's Avatar
Default Master Cylinder is Leaking
I took my s2000 into the dealership for service and found out my master cylinder is leaking. (I have an extended warranty) Should this be covered under warranty?
I dont drive my car hard, Never launched the car or anything.. Is this usual wear and tear?
thanx for all replies and feedback
Old Mar 7, 2006 | 01:55 PM
xviper's Avatar
It should be covered but since you've already taken it to your dealer, why don't you ask them?
Old Mar 7, 2006 | 02:01 PM
JasonX82's Avatar
the service rep wasnt sure until the warranty company gets back to him.
And just found out, Nope its not under warranty issue. its wear and tear or something iono.. =( doh..
well thanx for the reply
Old Mar 7, 2006 | 02:06 PM
xviper's Avatar
What a ripoff. A master cylinder shouldn't "wear out" in only 3 years.
Old Mar 7, 2006 | 02:30 PM
RACER's Avatar
[QUOTE=JasonX82,Mar 7 2006, 03:01 PM]the service rep wasnt sure until the warranty company gets back to him.
Old Mar 7, 2006 | 02:39 PM
JasonX82's Avatar
[QUOTE=RACER,Mar 7 2006, 11:30 PM] Brake pads, tires, all fluids, belts/hoses are normal wear and tear items.
Old Mar 7, 2006 | 02:52 PM
rworne's Avatar
Originally Posted by JasonX82,Mar 7 2006, 04:39 PM
Yeah, Well what i was told is they wont touch anything that has to do with the clutch assembly?...
What kinda bugs me is i never used my extended warranty and its almost up. This will probably be the first and last time i ever use it (hopefully) and im being denied.. LOL great investment i made on the extended warranty..
Look at it this way:
For Hondacare (I assume it's them) it was an EXCELLENT investment.
Old Mar 7, 2006 | 03:15 PM
Slows2k's Avatar
It all depends on the extended warranty company, better described as a "service contract".
Old Mar 7, 2006 | 03:54 PM
RACER's Avatar
Oh...I thought you were referring to the brake master cylinder, not that it makes a difference
Old Mar 7, 2006 | 05:32 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I assume you're talking about the clutch master. they all leak a little, if left with dirty fluid.
Change the clutch fliud, the leak will likely stop.
