Master Cylinder is Leaking
Old Mar 7, 2006 | 05:42 PM
RACER's Avatar
Originally Posted by billman250,Mar 7 2006, 06:32 PM
they all leak a little
They also leak through the cap if the level is too high. I found that if I fill just slightly below the top line, it wont leak through the cap.
Old Mar 7, 2006 | 05:44 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
true....
I usually find them leaknig under the dash. You'll see a drip sitting on the back of the master under the dash where the pushrod goes into it.
If you haven't changed your clutch fluid, go look now
Old Mar 7, 2006 | 05:52 PM
RACER's Avatar
I changed the fluid in the clutch master about 8k miles ago. If it were to spring a substantial leak, the fluid would eventually find it's way onto the carpet.
rusteds2k
19
Oct 3, 2007 07:01 AM
KS2002
Dec 20, 2006 06:11 PM
Tee Jay
Oct 27, 2005 05:50 AM
rajun asian
Jul 12, 2004 12:14 AM
bboersma
Nov 22, 2002 06:00 PM
