Megan Racing Catch CAN install questions
Ok I snagged a megan racing catch can pretty cheap here it is
Uploaded with ImageShack.us
Issue is I read the DIY on the cusco catch can and it seems that only has 2 ports on the can. This one has 3. I know one line comes off of the valve cover routes to the can then back to the pcv valve. What do I do with the other port on the can??
Look closely. this is mikeys2k engine he lists a megan catch can. he has on of the top ports going to the front outlet on valve cover. and a lower port going to the throttle body.
No he does not. He has one top port connected to the breather on the valve cover. You can clearly see that the PCV valve is still connected to the valve cover and the intake manifold. You can clearly see there is a blue hose connected to the intake manifold, but you can not see exactly what is is connected to.
What you see zip-tied to the blue hose connected to the front of the valve cover and catch can, is the blow-off valve vac line.
Catch cans "catch" oil. If you don't drain them, they fill up. If you connect the bottom port to anything, what can a can with a hole in the top and bottom really catch?
Just call 'em on Monday and find out.
General Phone : +1 (626)581-0988
General Fax : +1 (626)581-8334
Wholesale Fax : +1 (626)581-4332
General inquiry: info@meganracing.com
Tech support: support@meganracing.com
That picture is incorrect in displaying how a catch can should be plumbed.
The correct way is one port on the catch can goes to the PCV and then the second port of the catch can goes to the intake manifold. That's it! The front breather should remain stock. In order to "catch" blow by you need vaccum.
If that doesn't make sense, just think of it this way, look at the stock PCV setup, now you're catch can needs to be between it. That way it will catch oil.
