Metallic Clicking noise on cold starts
Old Jan 25, 2010 | 11:06 AM
ahrmike's Avatar
Default Metallic Clicking noise on cold starts
I'm wondering if this is a common s2000 noise or if mine is telling me its unhappy.
When I start the car up in the (relatively) cold Hawaii morning , I hear this metallic "clicking" noise. its not a card fluttery sound, its more of a click click click click which seems to happen with the RPMs of the car. I'm wondering if anyone had similar problems and what they did to fix it. I dont get excessive oil consumption, dont have smoke coming out from anywhere, oil always comes out clean, drain plug has no metal shavings, etc~ knock sensor also is NOT tripping. am I just being overly cautious?
I have this feeling its a valve tolerance problem/noise as I did do it myself (with some help + special tools from a honda mechanic).
If you guys got any ideas, lmk..thanks!
also, after it warms up, the noise quiets down but its still faintly there.
Old Jan 25, 2010 | 12:27 PM
turbo_slug's Avatar
do another valve adjustment?
Old Jan 25, 2010 | 12:34 PM
kenny_son's Avatar
ya i have the same noise. Im pretty sure i need a valve adjustment
Old Jan 25, 2010 | 12:48 PM
ahrmike's Avatar
^thanks guys. Yeah, I would except I gotta pick me up a few specialty tools (valve adjust tool...yeah I know you can ghetto rig it but want a real one), good feeler gauges, and a good piston holding tool.
for those who valve adjust DIY: how did you check "top dead center" for the piston? the mech I had help me checked it with a piston holding tool..can you use crank timing marks?
Old Jan 25, 2010 | 01:31 PM
SpitfireS's Avatar
First you line up the cam gears.
Do cyl #1.
Turn crank 180 degrees.
Do cyl # 3.
Do cyl #4.
Do cyl #2.
Once you see the valve train turning and opening / closing valves you see when you can adjust them when both sets of valves are free of the followers.
Old Jan 25, 2010 | 02:36 PM
ahrmike's Avatar
^Ah. always with the good information. thanks spitfire!
Vangelis
May 21, 2018 05:48 PM
francor10
Jun 23, 2012 10:48 PM
bizlipkick
Jul 12, 2006 07:38 AM
marcucci
Jul 2, 2001 06:02 PM
