Meth Injection
I have done some research with kits along with pricing. Every kit that I have read about is around the same price. The pros overwhelm the cons, and I will eventually go turbo so the meth injection will enhance that upgrade as well.
Here are my questions:
-Who has meth injection
-What kit did you use
-Where did you locate the tank/pump
-How hard was the install
-What is your take on this idea
not worth it unless you are FI
edit: reading owns me.. I see your looking to go FI..
never have installed a meth kit before but it looks very similar to a nitrous kit.
I've seen most people mount them in the trunk.
Have you decided on what engine management you will be using?
at this point none. of all of the research that i have done, its a straight plug in play and no additional tuning or other e-manage system is needed. for $400 or so, why not get something that will produce a bit more power, cleaner burn and more mpg?
try this section
https://www.s2ki.com/forums/index.php?showforum=193
or this section
https://www.s2ki.com/forums/index.php?showforum=34
they might be more receptive to your query
or this section
RAIN H8R
Nov 5, 2013 01:06 PM
