Misfire
hmm that its 3 individual cylinder misfire codes and one general misfires code correct? I would check the coil packs first, then wires and plugs. How many miles on the car? If it is not ignition check the fuel injectors. Ever run injector cleaner? type of gas you use? Mods? etc. would be helpful
First things first.
P0325 is a knock sensor. It's either bad, unplugged, or broken from a clutch install.
Don't even think about the other codes till you fix the knock sensor first.
Originally Posted by onfire01,Feb 24 2007, 09:19 AM
We dont have wires, buddy
This is Under the Hood and trust me wires may be a factor. Your new here so we'll cut you some slack! As for the "buddy" crap leave it at the door. Either shape up or go back to My Space.
Utah
Originally Posted by chrisesteban,Feb 27 2007, 06:35 PM
the car revs by itself when it cold now? any1 know if this is tied in with the misfire?
