Misfire
Old Feb 21, 2007 | 08:48 PM
chrisesteban's Avatar
Default Misfire
Hey guys my check engine light went on. pulled the codes and got P0325, P0301, P0302, and P0300. i know what the codes are but what causes them and how do i fix this. thanks!
Old Feb 21, 2007 | 09:12 PM
blackout's Avatar
hmm that its 3 individual cylinder misfire codes and one general misfires code correct? I would check the coil packs first, then wires and plugs. How many miles on the car? If it is not ignition check the fuel injectors. Ever run injector cleaner? type of gas you use? Mods? etc. would be helpful
Old Feb 23, 2007 | 02:42 PM
SumAznGuy's Avatar
https://www.s2ki.com/forums/index.php?showtopic=292304
Welcome to the club.
Old Feb 23, 2007 | 04:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
First things first.
P0325 is a knock sensor. It's either bad, unplugged, or broken from a clutch install.
Don't even think about the other codes till you fix the knock sensor first.
Old Feb 23, 2007 | 11:34 PM
i just replaced my knock sensor 2 months ago b/c it got damged during my motor rebuild.
Old Feb 24, 2007 | 08:19 AM
onfire01's Avatar
Banned
We dont have wires, buddy
Old Feb 24, 2007 | 01:43 PM
Utah S2K's Avatar
Any thought on the spark gets to the coil packs?
This is Under the Hood and trust me wires may be a factor. Your new here so we'll cut you some slack! As for the "buddy" crap leave it at the door. Either shape up or go back to My Space.
Utah
Old Feb 27, 2007 | 05:35 PM
the car revs by itself when it cold now? any1 know if this is tied in with the misfire?
Old Feb 27, 2007 | 06:14 PM
SOHCmyDOHC's Avatar
That one may be the map sensor or a vacuum leak
Old Feb 27, 2007 | 06:22 PM
thats wat i thought. cool
