misfiring ap1
Old Apr 12, 2013 | 09:14 AM
Real talk's Avatar
Default misfiring ap1
So I've been experiencing a misfire It's only on the low rpm accelerating for example as i'm letting the clutch out 1st gear it will have a little misfire on takeoff untill about 3k rpm it will get going it doesn't do this all the time but a good majority
It's a Low rpm Bog The idle misfires and pops accelerating 20% wont misfire anything more then that like a quick kick of the throttle to the floor will misfire unless its pressed slowly down
I've tried
Injectors
Map whack + zip tie
New spark plugs NGK laser platnium
Adjusting valves
any help would be awesome
Old Apr 12, 2013 | 11:37 AM
apme123's Avatar
did you do a compression test?
Old Apr 13, 2013 | 09:15 AM
Real talk's Avatar
yes 220-240 each cylinder
Old Apr 13, 2013 | 10:58 AM
apme123's Avatar
I would double check and test the ignition coil packs and wiring.
Cgb569
May 24, 2015 06:33 PM
chicomacattack
Jan 19, 2015 04:17 AM
XBMAX
Aug 11, 2013 11:36 AM
Real talk
Apr 11, 2013 12:29 AM
NFRs2kevin
Feb 26, 2010 03:24 PM
