missssfiring....no engine check or cel
This is EXACTLY the same problem I'm having. And it's intermittent. I'm kind of relieved to hear it's not just me, I actually thought it was a result of the computer getting confused by the 15degree (celsius) daily temperature swing in this crazy new city of mine.
Anyone care to recommend the best (and easiest) method of cleaning the injectors? A pressurized flush, or just run some STP injector cleaner through a tank?
ok just got new injector but still doin it wo its not injector ..sparkplug or coil...what else i can check... and i just put my amuse R1000..doing same thing so its not cat or exhaust... and that buc buc noise got louder with my R1000.... damn man..this thing i kill me...... now what get new ECU?.. IS IT SAFE TO DRIVING WITH THIS CONDITION?.. IT RUNS PERFECT.. any idea guys?>
I dont think dirty injectors would be the cause with only 40k miles. I would check with an NOID light to see if your injectors are maybe not getting power? Or with a Multimeter to see if there getting enough power or the right amount of Resistance. When you put the plugs in did you gap them correctly?
Originally Posted by zenkai_ate_you,Jun 13 2007, 06:20 PM
um...ok... can somebody explain to me why my exhause make buc buc noise when im at the stop sign and feelin that misfire thing too its just a little bit so somebody who seattin on passinger side person can even feel this but driver can
...T_T can i drive hard with this/>>>>??
https://www.s2ki.com/forums/index.ph...ic=292304&st=0
Short version = Injectors if it lines up with this thread
rjkoneill
Jun 29, 2016 03:25 AM
LATEOTT
Apr 23, 2008 11:18 AM
