Mixing Tranny fluids
Old Dec 14, 2014 | 04:28 PM
usafstud's Avatar
Default Mixing Tranny fluids
Anyone think it would be an issue to mix Honda MTF and Redline MTL fluid? I happen to have a bottle of each and it has been about 15k miles since last change. The car doea see some track time.
Old Dec 14, 2014 | 06:51 PM
Car Analogy's Avatar
I wouldn't. No urgency to changing the fluid. Just wait and get more of one brand.
Old Dec 14, 2014 | 06:52 PM
Adrenalize's Avatar
I don't think it's a good idea
Old Dec 14, 2014 | 07:02 PM
afzan's Avatar
There's a potential that the different additives used in the two MTF's can cause issues when mixed together
Old Dec 15, 2014 | 12:31 PM
zeroptzero's Avatar
Redline MTL is a bit thick, it works best in high temp use and it is a great fluid, the Honda MTF will thin it out though as it tends to be quite thin. But as mentioned by Afzan you really don't know if the friction modifiers in the two fluids will be compatible, the friction modifiers in Redline MTL are a very specific formula for synchronizer speeds. Only way to tell is to try it and report back, you can be our little guinea pig
Old Dec 15, 2014 | 01:01 PM
wadzii's Avatar
Banned
I've never used those 2 together, but I have used honda mtf and redline lightshock proof in high hp severely abused b-series trannys before with good results.
It wouldnt cause any issues but mixed fluids dont typically last as long as non "mixed" fluids do.
PistolPete76
Feb 5, 2013 12:22 PM
acn684
Jun 11, 2012 09:08 AM
passmans2kny
Jun 15, 2011 02:25 PM
webdiva
41
May 31, 2005 05:37 AM
