More Power to the Ground?
Old Nov 14, 2002 | 01:30 PM
vananron's Avatar
Default More Power to the Ground?
I know that the BHP is 240 on the S2000 but the RWHP only registers in the high 190's or very low 200's. I want to know if anybody has had any success in aftermarket parts that put more of the engine's power to the ground a.e. carbon fiber drive shaft, different transfer case etc.
Old Nov 14, 2002 | 02:08 PM
Schatten's Avatar
you'll always lose a certain % of the flywheel horsepower when its transferred to the wheels.
a cf driveshaft or something similar would only help the motor reach the power much quicker by lightening up the drivetrain.
btw, we don't have transfer cases =D this isn't a 4WD vehicle.
Old Nov 14, 2002 | 02:47 PM
ejis's Avatar
Lighter weight - well...lower inertia really - rotating parts (drive shaft, flywheel, wheels...) will make a difference in power to the ground as measured on a dyno, and as felt in acceleration, since that's all based on how quickly you can change the speed of the wheels. However, I don't really know of many parts to do this except wheels. BTW, a driveshaft has such a relatively small diameter, that lowering it's inertia noticeably would require a drastic change in construction and material, read expensive...
There are many easier ways to get some power, and this won't get you much. A 20% loss from flywheel to the ground isn't bad. Also, we can't really verify what the engine is making at the flywheel, we just take Honda's word for it and assume "240 hp" even though everyone's engine is different and any one may make less - or more.
Old Nov 14, 2002 | 02:50 PM
xviper's Avatar
Have you considered 4.44 or 4.77 rear gears?
Old Nov 14, 2002 | 03:40 PM
vananron's Avatar
I thought about changing the gears, but I am concerned about the fact that I would be shifting too many times, so you know at what mile per hour you need to shift in first gear with 4.44 or 4.77 gears?
Old Nov 14, 2002 | 03:49 PM
xviper's Avatar
I shift by "tach" not by road speed so I couldn't tell you. There are speed calculators available if you want to know the speeds in each gear. Here's a thread I started that talks about all kinds of stuff after a 4.44 gear swap:
https://www.s2ki.com/forums/showthread.php?...&threadid=85331
spdracerut
Nov 14, 2019 06:20 AM
offroadr35
Aug 7, 2017 03:11 PM
turbo997
Jun 30, 2006 05:51 AM
campbuds
Jun 6, 2006 07:02 PM
malachi
Mar 30, 2001 08:43 AM
