make the sk2 more POWER efficient
Old Jun 26, 2006 | 10:48 PM
turbo997's Avatar
Wink make the sk2 more POWER efficient
I been reading through previous threads about DYNO/MOD/POWER etc.. and realize that the s2000 [B]doesn
Old Jun 26, 2006 | 11:09 PM
prorcracer87's Avatar
only mod that can get u over 300hp is forced induction:turbo or s/c
not all 240 get to the wheels because of drivetrain loss, theres drivetrain loss on every car, more on autmatics and manuals most of the time.
Old Jun 26, 2006 | 11:27 PM
iam7head's Avatar
old sae measure power with the motor apart, which takes out alot of variables.
1)turbo/supercharge would be the easiest route, a stoker kit 2.5liter is availble from inline4, don't know how much it pushs tho'. you can't get best of both world, if you want more power, things that make to handle only 240 bhp is going to give you crap.
2) better tires, syn. fluid, lighten drive shaft, different LSD, rear end, axle, lighten flywheel better clutch, etc
3)fraction, notice all heat engine will not be 100% effeicent, that's the law of physic, you are only using 12-15 percent of all the power you get from burning gas.
what can happen? everything.
the easiest way to achieve 300+ and lot of torque without forceinduction and without risking your honda dohc is to get a ls1 swap. the motor and trans is going for 1500, add a custom shaft and rear end, bam you have something torquey.
(sorry, rotary fans)
oh..that's some cutting, welding and alot wiring involved
most car will have a 12% fwd drive train loss, rwd will be more due to the(transmission not transaxle like mr/ff set up) will have a slight more loss.
Old Jun 27, 2006 | 07:21 AM
afwfjustin's Avatar
When car companies tell you a car makes so and so power, they are talking about the engine, not the car. For instance, our motor makes 240 horsepower when you lay it on a table and hook it up to a machine. When you put it in a car, the CAR eats up some of the power to get it moving, then the rest is the number you see at a dyno.
180 is very low, that must be from a mustang dyno. Usually you will see 190-210 stock.
Keep in mind that every other car out there has this "dilemma". The 300hp Mustang GT makes nowhere near 300hp...
Old Jun 27, 2006 | 07:26 AM
vtec9's Avatar
Originally Posted by turbo997,Jun 27 2006, 02:48 AM
2: Whats are some things that can go wrong with the car, that would cause the HP to dip the 237?
as mentioned, it takes power to spin the tranny, the driveshaft, the differential, the axels, and the wheels. this is where the power gets eaten up and why you only see 190-210 horse power AT THE WHEELS, which is what a conventional dyno measures.
Old Jun 27, 2006 | 07:56 AM
Paul S's Avatar
Adding to what others have said, there is no way that you can avoid shortening the life of the engine if you are up in the 300+ hp range.
Get gears if you want to feel more "power" without sacrificing the engine.
Old Jun 27, 2006 | 09:11 AM
turbo997's Avatar
Gears sounds interesting. How much power can one expect? Also, which brand?
Thanks,
Old Jun 27, 2006 | 09:16 AM
Paul S's Avatar
Just wondering, do you have an S2000?
Old Jun 27, 2006 | 09:24 AM
frank b's Avatar
Thanks,
You can't get any power from gears. You just sort of distribute it differently!
dcg's Avatar
dcg
Thanks,
Gears don't give you any more power, they just allow you to go faster with the power you've got, at the expense of higher rpms when cruising.
