Motul Oil
What would you reccomend in the Motul Brand?
Gear Competition
100% Synthetic
Specially formulated for gearboxes and limited-slip differential of racing cars. Excellent stability at high temperatures.
MOTUL exclusive technology approved in extreme endurance racing conditions : 24H du Mans, japanese GT Championship, on HEWLAND and X-TRAC gearboxes.
API GL-5
Gear 300 75W90
100% Synthetic
For gearboxes, differential of high performances and racing cars.
0% Shear loss.
Improved efficiency
API GL-5.
MIL-L-2105D.
Motylgear 75W80
Technosynthese
Smooth shifting
API GL-4 et GL-5
MIL-L-2105D
Motylgear 75W90
Technosynthese
Smooth shifting. High temperature stability.
API GL-4 et GL-5
MIL-L-2105D
Gearbox 80W90
Mineral
Reinforced with M0S2. Particularly recommended for heavily loaded gearboxes.
API GL-4 and GL-5.
MIL-L-2105D.
HD 80W90
Mineral
API GL-4 et GL-5
MIL-L-2105D
Gear MB 80W
Mineral
API GL-4
MB 235.1
Gear Competition
100% Synthetic
API GL-5
Gear 300 75W90
100% Synthetic
0% Shear loss.
Improved efficiency
API GL-5.
MIL-L-2105D.
Motylgear 75W80
Technosynthese
Smooth shifting
API GL-4 et GL-5
MIL-L-2105D
Motylgear 75W90
Technosynthese
API GL-4 et GL-5
MIL-L-2105D
Gearbox 80W90
Mineral
API GL-4 and GL-5.
MIL-L-2105D.
HD 80W90
Mineral
API GL-4 et GL-5
MIL-L-2105D
Gear MB 80W
Mineral
API GL-4
MB 235.1
I wouldn't put any GL-5 rated fluid in the tranny, even if it's dually rated GL-4. Not guarenteed to be yellow metal safe and can damage the syncros. Some people have used GL-5 fluids with brass synchros with no issues, but it's not worth the risk to me.
As for differential fluid you have more flexibility. Anything that meets honda specs should be fine. However I would be wary of the competition fluid if you plan to drive your car much on the street. The competition fluid may require more frequent changes than a more streetable fluid. The competition fluid may protect 'better' but may not last as long.
If you want a good track oil try NEO synthetic. They're located in Signal Hill. A lot of professional teams in Japan and europe use their oils. If you call baker precision ask for Hung he'll help you out.
www.bakerprecision.com
Motul oil's are superb. Myself and a number of highish BHP Impreza guys use them.
Smells like bubble gum
In the Honda I use 5W40 V300 oil, but we have colder climates in the UK than most in the US.
Not sure on the gear oil as I use Silkolene in that.
MB
MB
