Mugen exhaust with test pipe
Sorry in advance if this has been discussed before, but I could not find anything in a search. Now, is running a test pipe actually worth the trouble?? Seems like a lot of guys say it helps with some type of aftermarket ecu, but I'm running just mugen bolt ons. It would be especially helpful if I could get feedback from guys running a test pipe with the mugen exhaust.
tks
tks
Although I don't have the Mugen exhaust (j's n1 here), I'm planning on installing the Spoon test pipe. I think I've read that running the stock ECU with straight pipe will cause the *check engine* light to go on. With a boosted set up, removing the cat will give bigger, more noticeable gains. With an N/A set up, there will be very little gains, since our stock cat flows very well.
I am running T1R a test pipe with stock exhaust. The engine check light went on and there's no problem with the engine. I can feel noticeable low-mid-range improvement. The test pipe is cheap and I think it is a worthy upgrade but you just have to live with an engine check light on.
I've read about guys by-passing the cel, but I can't find the thread. BTW whats a T1R test pipe and how much do they run?
You have that amuse ecu right? A lot of guys say a test pipe will only help either on a FI car or one that has an aggressive ecu. I'd still like to try on though.
This works for the CEL, so i've heard
As for test pipes and performance, I believe there is a difference in the low-mid- range as stated...The car sounds A LOT more aggressive as well. Check out my sig, I am coming out with a test pipe soon.
The fact that the Mugen ECU bypasses the secondary 02 sensor allowed me to think that all the Mugen goodies plus a test pipe would equal some great bolt on power.
Why don't you try that Stu, aren't you gonna get the ECU? Make sure you get the temp gadgets.
